RC INNOVATIONS FAST 500HZ ESC
Gadman
MessagePosté le: Sam 7 Avr - 18:59 (2012)    Sujet du message: RC INNOVATIONS FAST 500HZ ESC Répondre en citant
Bonjour à tous
J'ai trouvé ça:
Je crois que c'est fait par un Espagnol:
http://www.multicopters.es/foro/vbulletin/showthread.php?35-RC-INNOVATIONS-…
http://shop.ebay.fr/rc-innovations/m.html?hash=item3a72d1a203&item=2510…
La boutique:
http://www.rc-innovations.es
Description en Anglais (pas tout compris  Embarassed )
Citation:
ONLY FOR MULTICOPTERS!!! NOT VALID FOR PLANES, CARS OR BOATS.
Description
- With all multicopters (except motor output I2C).
- More stability, more precision flying, the wind has less effect on the fly.
- High quality components and thorough quality control, the brushless speed controller ESC are tested each unit.
- Fast PPM 500hz, 10X faster than other normal ESC.
- Quantity: 1 Set.
Specification
- Output: Continuous 30A, Burst 40A up to 10 Secs.
- Input Voltage: 2-4 cells lithium battery or 5-12 cells NiCd/NIMh battery.
- BEC: 2A / 5V (Linear mode).
- Max Speed: 210,000rpm for 2 Poles, 70,000rpm for 6 poles, 35,000rpm for 12 poles.
- Size: 46mm (L) * 26mm (W) * 7mm (H).
- Weight: 32g.
Features
- Safety Arming Feature: Regardless the throttle stick position, the motor will not spin after battery connected.
- Throttle Calibration: Throttle range can be configured to provide best throttle linearity, fully compatible with all market available transmitters.
- Preprogrammed for multicopter. programming is not possible.
- Not cut for low battery voltage (for security).
- Not brake.
Gadman
Un jour, peut être...
MessagePosté le: Sam 7 Avr - 18:59 (2012)    Sujet du message: Publicité
MessagePosté le: Sam 7 Avr - 19:00 (2012)    Sujet du message: RC INNOVATIONS FAST 500HZ ESC Répondre en citant
pâs mal
je veut bien en tester 8 gratuitement Mr. Green
MessagePosté le: Sam 7 Avr - 19:16 (2012)    Sujet du message: RC INNOVATIONS FAST 500HZ ESC Répondre en citant
a mon avis ce sont de simple rctimer ,flashé et reconditionné et vendu plus cher
MessagePosté le: Sam 7 Avr - 19:40 (2012)    Sujet du message: RC INNOVATIONS FAST 500HZ ESC Répondre en citant
bonjour,
bien vu Titeuf,
il s'agit bien de ça, même couleur pour les fils, même section 16AWG, même position du condensateur et même inscription sur son container "105° PET", ils ont pas osé en mettre un à l'envers
quand à Loupblanc je pensais pas que 30 amp pouvaient lui suffire surtout que c'est pas un vrais 30 amp, il n'y a que 15 transistors à effet de champs (Mosfeet)
Gadman
MessagePosté le: Sam 7 Avr - 19:47 (2012)    Sujet du message: RC INNOVATIONS FAST 500HZ ESC Répondre en citant
Salut à tous
Ben, pour un nigeau comme moi c'est une bonne chose, sauf pour mon porte monnaie Embarassed
MessagePosté le: Sam 7 Avr - 19:53 (2012)    Sujet du message: RC INNOVATIONS FAST 500HZ ESC Répondre en citant
salut,
y a pas de nigaud là dedans, c'est tout simplement la preuve que tu cherches à faire avancer le schimlblick en trouvant des nouvelles choses
MessagePosté le: Sam 7 Avr - 20:12 (2012)    Sujet du message: RC INNOVATIONS FAST 500HZ ESC Répondre en citant
j 'en ai reçu 4
je teste a priori oui ce sont des rc timer
ceux de geek tiennet tres bien avec des moteurs de 350w
Gadman
MessagePosté le: Sam 7 Avr - 23:05 (2012)    Sujet du message: RC INNOVATIONS FAST 500HZ ESC Répondre en citant
Merci pour vos infos Okay
Je suis en train de me faire une petite config "virtuelle" dans ma tête avec des éléments ayant le meilleur rapport qualité-prix.
Je commence à avoir quelques pistes en partie grace à ce forum.
Je vais certainement acheter les elements un part un pour faire passer plus facilement l'addition, je ne suis pas pressé.
Gadman
MessagePosté le: Dim 8 Avr - 06:37 (2012)    Sujet du message: RC INNOVATIONS FAST 500HZ ESC Répondre en citant
Un petit bémol , ll ne donne pas la version du soft simonk utilisée et il ne dit pas si il les teste individuellement sur banc  Shocked
Après les espagnols ont besoin d'argent , il parait !!!!!
MessagePosté le: Dim 8 Avr - 07:48 (2012)    Sujet du message: RC INNOVATIONS FAST 500HZ ESC Répondre en citant
un bon point pour greek et puis avoir des 500 h alors que ca sort en 400 je vois pas tres bien l avantage
MessagePosté le: Dim 8 Avr - 14:10 (2012)    Sujet du message: RC INNOVATIONS FAST 500HZ ESC Répondre en citant
la courbe de gaz linéaire apporte enormement Cool
et le surplus de rapidité n est pas négligeable non plus
a ce prix,je prefere acheter ça a notre cher greek qui lui ,test un par un les esc et a qui on peut faire confiance
MessagePosté le: Mar 10 Avr - 16:05 (2012)    Sujet du message: RC INNOVATIONS FAST 500HZ ESC Répondre en citant
Ah oui tu fait cela Mr Geek?
une info sur les prix que tu pratique?
MessagePosté le: Mar 10 Avr - 17:05 (2012)    Sujet du message: RC INNOVATIONS FAST 500HZ ESC Répondre en citant
Oh les yvelines Very Happy  !!!
Tu as tout là
http://achetechinois.xooit.fr/t756-Vends-ESC-Rc-Timer-30-Amp-flashe-400.htm
Aprés tu passes par MP
MessagePosté le: Mer 11 Avr - 06:25 (2012)    Sujet du message: RC INNOVATIONS FAST 500HZ ESC Répondre en citant
Tu as tout là
Merci Mr
Gadman
MessagePosté le: Jeu 12 Avr - 08:01 (2012)    Sujet du message: RC INNOVATIONS FAST 500HZ ESC Répondre en citant
GREEK 13 a écrit:
Tu as tout là
Super Okay
Je n'avais pas vu ce post Embarassed
MessagePosté le: Aujourd’hui à 11:12 (2017)    Sujet du message: RC INNOVATIONS FAST 500HZ ESC
