WKM bientôt sur Ipad et 4s ou plus ?
Aller à la page: 1, 2, 3  >
MessagePosté le: Lun 17 Déc - 22:38 (2012)    Sujet du message: WKM bientôt sur Ipad et 4s ou plus ? Répondre en citant
Trouvé sur un forum chinois :
order to enhance the user experience, DJI upcoming IPAD ground stations, Mobile Assistant Software IOSD MARK II.
IPAD ground station:
Hardware requirements: IPAD and Bluetooth radio
advantages:
1, since then you can get rid of laptop carrying inconvenience troubled, and do not need to install the map without the need to install the driver, no need to consider the version of the Windows OS compatible google earth to fight, not to worry not open problem.
2, you do not need to be over the wall, and does not require lengthy data cable, like to play games on the IPAD, you can enjoy the wonderful feeling of the ground station control aircraft!
IPAD ground station software users noble fashion the UI more worthy of your expectations!
Mobile Assistant Software:
Hardware requirements: IPHONE 4S and above, or IPAD3, Bluetooth to USB module advantages:
1 using a mobile phone at any time parameter adjustment, upgrade master, bulky and inconvenient to get rid of computer.
2 user parameters automatically sync to the cloud server, replace the phone configuration parameters, instant recovery.
3, the use of low-power Bluetooth communication, at least reduce the adjusted reference phone energy consumption.
4, easy to use, automatically save the last record linkage, password security mechanism to prevent wrong connection.
The IOSD MARK II , when the synchronized release IOSD Assistant Software, IOSD online upgrade!
strong adaptability, the outside temperature of -20 to +40 degrees normal use without adapters.
the data recording function, can record the input, output, GPS satellite number, voltage, distance HOME point distance, height of flight data, the user can take advantage of the Assistant Software to view the recorded data.
the existing IOSD utilization Assistant Software upgrade with 1 and 3 function. Pictures and test video to follow!
Effectivement en voyant une microSD dans l'OSD on comprends bien que les infos peuvent être stockées...
Attention ne pas prendre en compte la modif electrique sur là droite (le gars a modifier l'alim)
MessagePosté le: Lun 17 Déc - 22:38 (2012)    Sujet du message: Publicité
MessagePosté le: Mar 18 Déc - 17:18 (2012)    Sujet du message: WKM bientôt sur Ipad et 4s ou plus ? Répondre en citant
ca y est les derniers remparts MK vont etre aneantis!! l'enregistrement des parametres!!
MessagePosté le: Mar 18 Déc - 22:30 (2012)    Sujet du message: WKM bientôt sur Ipad et 4s ou plus ? Répondre en citant
c est bientot la fin du monde ou le debut d une nouvelle aire Wink
MessagePosté le: Mar 18 Déc - 22:34 (2012)    Sujet du message: WKM bientôt sur Ipad et 4s ou plus ? Répondre en citant
Je penche pour la seconde idée
MessagePosté le: Mar 18 Déc - 22:36 (2012)    Sujet du message: WKM bientôt sur Ipad et 4s ou plus ? Répondre en citant
Moi aussi  Mort de Rire Mort de Rire Mort de Rire
i2c fucker
MessagePosté le: Mer 19 Déc - 02:58 (2012)    Sujet du message: WKM bientôt sur Ipad et 4s ou plus ? Répondre en citant
http://static.youku.com/v1.0.0293/v/swf/loader.swf?VideoIDS=XNDkwMDYwMjUy&embedid=ODYuNjkuMTkwLjIxNwIxMjI1MTUwNjMCYWNoZXRlY2hpbm9pcy54b29pdC5mcgIvdDIyMjctV0tNLWJpZW50b3Qtc3VyLUlwYWQtZXQtNHMtb3UtcGx1cy5odG0%3D&wd=
I can see ! I can Fly !
MessagePosté le: Mer 19 Déc - 09:37 (2012)    Sujet du message: WKM bientôt sur Ipad et 4s ou plus ? Répondre en citant
C'est bien mais toujours pas homologable chez nous en pro. Dommage  Rolling Eyes
Je vais encore garder le MK et ses difficultés de réglage
MessagePosté le: Mer 19 Déc - 10:03 (2012)    Sujet du message: WKM bientôt sur Ipad et 4s ou plus ? Répondre en citant
va plus rester beaucoups de raisons....puisque les paramètre de vols sont enregistrables
MessagePosté le: Mer 19 Déc - 12:54 (2012)    Sujet du message: WKM bientôt sur Ipad et 4s ou plus ? Répondre en citant
Au regret de vous annoncer cela, mais les cartes zerouav  le x6 ou la x4 enregistre d'origine les paramètres de vole, ce qui permet de relire la totaliser de son vole sur pc, avec les infos positions, vitesse, alti, tension, vibration, consommation, alerte... position des manche de la rc........ tous quoi)
cela ce passe par exemple sur andoid dans un répertoire nommé: YShj, puis les fichier du type: T20120826195131.hj, exportable sur pc puis relisable via l'applis PC.
MessagePosté le: Mer 19 Déc - 13:00 (2012)    Sujet du message: WKM bientôt sur Ipad et 4s ou plus ? Répondre en citant
Il reste à forcer l'atterrissage quand le multi sort du périmètre de vol: hauteur/distance et.......que la DGAC accepte à nouveau ce matériel.
Pour l'instant hors MK pas de salut.
MessagePosté le: Mer 19 Déc - 14:12 (2012)    Sujet du message: WKM bientôt sur Ipad et 4s ou plus ? Répondre en citant
Enregistrable sur la machine en vole (via mémoire SD ou autre) ou sur la ground station (android via wifi ou autre) ? car c'est pas la même chose  Rolling Eyes  pour le coup multiwii/ardupirates/etc le font aussi en bluetooth ou xeebee  Mort de Rire
MessagePosté le: Mer 19 Déc - 17:14 (2012)    Sujet du message: WKM bientôt sur Ipad et 4s ou plus ? Répondre en citant
Tous le font soyez pas jaloux, lol Mr. Green
C'était juste pour dire que je n'avais pas percuté qu'il y avait une sd dans la boiboite Mort de Rire
MessagePosté le: Mer 19 Déc - 17:28 (2012)    Sujet du message: WKM bientôt sur Ipad et 4s ou plus ? Répondre en citant
MessagePosté le: Mer 19 Déc - 18:08 (2012)    Sujet du message: WKM bientôt sur Ipad et 4s ou plus ? Répondre en citant
T'inquiète cela viens chez DJI. La hauteur maxi est déjà disponible et fonctionne très bien.
Very Happy
MessagePosté le: Mer 19 Déc - 22:48 (2012)    Sujet du message: WKM bientôt sur Ipad et 4s ou plus ? Répondre en citant
advantages:
Si je comprends bien on pourra enregistrer les paramètres de vol, sans avoir besoin d'un Iphone avec son PC et l'assistant IOSD MarkII ?
Faudra juste brancher l'osd au PC pour récupérer les paramètres.
En espérant qu'il mettront un jour l'appli sous android.
MessagePosté le: Aujourd’hui à 10:25 (2017)    Sujet du message: WKM bientôt sur Ipad et 4s ou plus ?
Page 1 sur 3
