ACHETER CHINOIS? c'est possible!Acheter en Chine,forum modelisme multirotors DIY!
Nouveau ! ACHETER CHINOIS? c'est possible! est désormais compatible avec l'extension FastNews.kiwi disponible pour votre navigateur. Avec cette extension, vérifiez s'il y a des nouveaux sujets sur ce forum en un clic depuis n'importe quelle page ! Cliquez ici pour en savoir plus.
Auteur |
Message |
Posté le: Jeu 24 Jan - 18:41 (2013) Sujet du message: Chassis Bumblebee ST800 |
Wheelbase:820mm Height:440mm Empty Frame Weight:1090g Payload Capability:1500~2500g Flight Time:>10 minutes We recommend you use propeller with 15 inch。
1.The machine mainly consists of carbon fiber composite materials, matching joints of aluminum alloy to ensure the strength of body as well as to effectively reduce the weight. 2. The six arms are with 18mm carbon fiber tubes and enhanced motor mount. 3. The connections of landing gear are formed with 14mm carbon fiber tube,which is composed with metal and carbon fiber,to be assembled and repaired easily. 4. Supporting tubes are made from 12mm carbon fiber tube, the span between tubes is 155mm, it accommodates with mainstream camera gimbal in the market. 5.There are two extended boards in front and rear of the fuselage,it is convebient for the installation of GPS, receivers and other equipments. 6.Battery frame is fixed by metal connectors,the canter of gravity of the aircraft can be adjusted by slidding the battery frame back and forth.
Page officielle du constructeur : http://www.hobbylord.com/en/content/?201.html
Télécharger la notice de montage : http://www.hobbylord.com/down/ST800_manual.rar
Sites vendeurs :
http://www.omgfly.com/index.php?main_page=product_info&cPath=1_41&products_id=949 http://www.rchobby-avenue.co.uk/bumblebee-st800-kit-aircraft-6axis-flyer-he… _________________ Quadri DJI 450, electronique wookong, radio spektrum DX8, gopro HD2
Revenir en haut |
Posté le: Jeu 24 Jan - 18:41 (2013) Sujet du message: Publicité |
Revenir en haut |
Posté le: Jeu 24 Jan - 20:05 (2013) Sujet du message: Chassis Bumblebee ST800 |
interressant celui la, mais maintenant je me mefie des trucs qu'ils annoncent (comme le fy680 , tout carbonne 3k et en fait le centerplate sont de la fibre de verre camouflées entre deux plaque de carbonne ) et de la solidité des produits frame chinoises, notamment leurs support moteurs :-(
bref je tenterais bien, mais j'ai peur d'etre decu une nouvelle fois _________________ -naza gps /xaircraft X4 650V/moteur 2834 ca 10 -esc 30a greek - 10x5 graupner -4s@5a - MK original- chassis alu pliable x4,moteur ahm 36/6,helice 12x6 - 4s@8A - f330 naza gps origine - 3s@2,7A - exa tarot,3506-25,esc 30a,wm,11x5 -4s@5a |
Revenir en haut |
Posté le: Jeu 24 Jan - 21:11 (2013) Sujet du message: Chassis Bumblebee ST800 |
Pour les pros du chassis, Comment vous expliquez la différence de poids avec le tarot (environ 600g) par exemple et l'hexa bumblebee 1100g, parce qu'en terme de taille c'est kif kif (un peu plus grand tout de même pour le bumblebee) ?  _________________ Quadri DJI 450, electronique wookong, radio spektrum DX8, gopro HD2 |
Revenir en haut |
Posté le: Ven 25 Jan - 07:54 (2013) Sujet du message: Chassis Bumblebee ST800 |
Rien que sur les bras il doit y avoir une belle difference de poids. Les supports moteurs doivent être plus lourd, plus le poids de la coque, plus + + plus le poids annoncé qui n'est surement pas le bon . Enfin bon c'est toujours pareil
fjnetcom a écrit: | interressant celui la, mais maintenant je me mefie des trucs qu'ils annoncent (comme le fy680 , tout carbonne 3k et en fait le centerplate sont de la fibre de verre camouflées entre deux plaque de carbonne ) et de la solidité des produits frame chinoises, notamment leurs support moteurs :-(
Pour le tarot, je ne suis même pas sur que se soit de la fibre au niveau des center plate, quand tu perce ça fait un joli copeau genre ABS. Par contre les bras sont hyper light. _________________ Hitec Aurora9 Quadricoptère Frame Tarot Iron Man x650, moteurs T-Motor MT3506-25, ESC HK Afro, Naza+GPS, LiPo Zippy 4S 20C 5000, hélices carbonse T-Motor 12x4,5 FPV: Mini OSD DJI, TX DJI 630mW Nacelle brushless Tarot 2D |
Revenir en haut |
4X4lololab
Posté le: Dim 27 Jan - 12:39 (2013) Sujet du message: Chassis Bumblebee ST800 |
Quelqu'un l'aurait-il commandé? _________________ Qui a peur, est un peureux...!!! Qui mange chien..... Chihuahua!!! URSUS XL pour le FPV 635 spider X4 frame dédié FPV Rabbit inside HJ-H4 en cours de montage |
Revenir en haut |
Posté le: Dim 27 Jan - 13:08 (2013) Sujet du message: Chassis Bumblebee ST800 |
4X4lololab a écrit: | Quelqu'un l'aurait-il commandé?
Il vient tout juste de sortir, Sur le papier ce chassis à l'air sympa, quoique plus lourd et destiné à porter plus lourd aussi. Pour ma part je viens tout juste de recevoir le tarot fy680, avec les problèmes lié aux fixations cassantes. pour l'instant, je ne sais quoi faire : - tenté de corrigé tous les problème du tarot - commandé celui là, et faire mon choix avec les 2 en mains. Je sais que sur le forum certains, sont propriétaire du bumblebee quadro, qui avait l'air pas mal. En tout cas avec moins de problèmes. j'imagine qu'entre l'hexa et le quadro, la qualité doit être similaire !!??
Penchy a écrit: | Rien que sur les bras il doit y avoir une belle difference de poids. Les supports moteurs doivent être plus lourd, plus le poids de la coque, plus + + plus le poids annoncé qui n'est surement pas le bon . Enfin bon c'est toujours pareil
T'es dur, parce que concernant le poids, du chassis le fy680 est proche des spécifications annoncés. Pour le reste .... je ne peux pas te donner tort
Si j'étais toi, j'attendrai que les américains le test avant de faire mon choix.
Revenir en haut |
Posté le: Dim 27 Jan - 14:22 (2013) Sujet du message: Chassis Bumblebee ST800 |
Pour le tarot le poids est bien celui annoncé mais parfois se n'est pas le bon. Mais pas forcement dans le mauvais sans. Dur d'être sûr avec les infos des revendeurs _________________ Hitec Aurora9 Quadricoptère Frame Tarot Iron Man x650, moteurs T-Motor MT3506-25, ESC HK Afro, Naza+GPS, LiPo Zippy 4S 20C 5000, hélices carbonse T-Motor 12x4,5 FPV: Mini OSD DJI, TX DJI 630mW Nacelle brushless Tarot 2D |
Revenir en haut |
Posté le: Dim 27 Jan - 14:35 (2013) Sujet du message: Chassis Bumblebee ST800 |
Penchy a écrit: | Pour le tarot le poids est bien celui annoncé mais parfois se n'est pas le bon. Mais pas forcement dans le mauvais sans. Dur d'être sûr avec les infos des revendeurs
Pas faux, sur le site officiel ils annoncent 1250g, mais avec un train différent.
j'ai l'impression au vu des nouvelles photos que le train n'est pas repliable
Mise à jour du post : Page officielle manuel d'instruction de montage (miam) _________________ Quadri DJI 450, electronique wookong, radio spektrum DX8, gopro HD2 |
Revenir en haut |
4X4lololab
Posté le: Dim 27 Jan - 14:44 (2013) Sujet du message: Chassis Bumblebee ST800 |
Revenir en haut |
4X4lololab
Posté le: Dim 27 Jan - 23:42 (2013) Sujet du message: Chassis Bumblebee ST800 |
TotoKor a écrit: | j'ai l'impression au vu des nouvelles photos que le train n'est pas repliable
Idem sur la notice
Moi ce qui m'inquiète, c'est que sur OMGfly ou sur RCHobby, les config annoncées ne fonctionnent pas sous ecalc... Les spécifications moteurs ne correspondent pas...
Si je comprends bien, chez RCHobby les ESC, moteurs et hélices carbones en 15" sont comprisent? _________________ Qui a peur, est un peureux...!!! Qui mange chien..... Chihuahua!!! URSUS XL pour le FPV 635 spider X4 frame dédié FPV Rabbit inside HJ-H4 en cours de montage |
Revenir en haut |
4X4lololab
Posté le: Lun 28 Jan - 14:49 (2013) Sujet du message: Chassis Bumblebee ST800 |
Confirmation pour le train d’atterrissage...
J'ai envoyé un mail à RCHobby:
Citation: |
Hi,
Thanks for your great shop.
I've any questions about Bumblebee ST800 Kit Aircraft 6-axis flyer Hexacopter.
If I understand, ESC and Propellers and Motors are inclued with the frame?
With the frame is it a quick foldable landing gear? In the HobbyLord site (instructions manual), it's not the same landing gear than yours (your pictures)
Have you got actually this product in stock?
How many days for comming in France?
Best regards and sorry for my English
Laurent
Voici leur réponse:
Citation: | Hi Laurent,
Thank you for your email.
Yes, ESC, motors, props and frame are included and no, it cannot be folded like the Bumblebee.
Yes, the ST800 is currently in stock and will take about 5-6 days to arrive to you door after it has been despatched.
Should you have any more questions regarding our products or services, do not hesitate to contact us at any time. We normally reply within 48 hours.
Je trouve très dommage pour le train d'atterrissage car le reste est pliable. Quel peut en être l'intérêt?
Revenir en haut |
Posté le: Lun 28 Jan - 22:07 (2013) Sujet du message: Chassis Bumblebee ST800 |
4X4lololab a écrit: | Citation: | Je trouve très dommage pour le train d'atterrissage car le reste est pliable. Quel peut en être l'intérêt?
Il existe trés peu de frame avec train pliable, les seules que je connaisse sont fy680 et le s800 avec son nouveau train qui côute un bras. Il en existe surement d'autres mais je ne les connait pas, en tout cas pour les frames commerciales. Pour les dyi je pense que ça se trouve. Aprés il est peut être possible de bidouillé le train pour le rendre pliable?!! Sinon le démonter pour le ranger.
On arrive sur une frame qui commence à être imposante (même s'il y a plus gros). Et les proprio de ce type d'engin, ont tendance à mettre une nacelle 3d. Donc dans ce cas là, le train du chassis il saute. Le nouveau train faisant partie de la nacelle. Et la nacelle elle est pas pliable. Donc l'un dans l'autre....  _________________ Quadri DJI 450, electronique wookong, radio spektrum DX8, gopro HD2 |
Revenir en haut |
4X4lololab
Posté le: Lun 28 Jan - 23:46 (2013) Sujet du message: Chassis Bumblebee ST800 |
Ouais c'est pas faux
En fait à la base j'avais dans l'idée de me faire à partir d'un train pliable tel celui du Bumblebee X550, un rétractable "motorisé" un peu comme certaines config de S800. Mais il est clair qu'avec une nacelle telle que OMGFLY 2 Axes 360° Camera Mount V2 il est vrai que je n'ai plus besoin de cette option...
Merci pour ton avis
@mitié
Laurent
Revenir en haut |
4X4lololab
Revenir en haut |
Posté le: Aujourd’hui à 03:35 (2018) Sujet du message: Chassis Bumblebee ST800 |
Revenir en haut |
