WKM FW 5.24
MessagePosté le: Ven 19 Juil - 20:57 (2013)    Sujet du message: WKM FW 5.24 Répondre en citant
http://www.dji-innovations.com/download/wookong-m-waypoint-downloads/
WooKong Multi Rotor Product Release Notes
© 2012-2013 DJI Innovations. All Rights Reserved.
Date : 18/07/2013
Release Status : Evaluation
WooKong M firmware version : 5.24
WooKong M software version : 2.02
WM Assistant version : 1.4.21
WooKong M Quick Start Guide : 1.04
What’s new?
Firmware
  • Fix the problem that Go-Home switch cannot be successfully triggered sometimes.
  • Add alternative Yellow and Green LED to indicate Abnormal Compass Data. The autopilot system will enter into ATTI Mode
automatically (ATTI and Manual Mode is free form influence.), and regain the original control mode once data is back to normal.
  • Flight Functions are restricted within the radius of 15Km from Tiananmen Square in Beijing, China.
  • Fix the problem of slight vibration caused by heavy-load aircraft during violence flight.
  • Add function of Motor Test.
  • Change the LED Indicators of IOC, Direction recording is green blinking, POI is cyan blinking and Home point is purple blinking.
  • Add a new LED Indicator for recorded Home Point. When control mode is not Manual, and the satellites number MC has
  • searched is more than 6, LED Indicator will blink 6 purple flashes regularly if the distance between the aircraft and recorded
Home point is less than 8m.No blinks if the distance is beyond 8m or the control mode is Manual.
  • Fix the function of Mapping (GIS) Aerial Auxiliary in DJI Ground Station.
Software
  • Add configuration of Motor Test function in Basic->Aircraft.
  • Delete the MC output Switch in WM Assistant.
Manual
  • Add description of Abnormal Compass Data indicator.
  • Add description of Flight Restriction in Specified Area.
  • Add solution for Abnormal Cases in Motor Test.
  • Add description that Attitude Controllable When One Motor Output is Failed.
  • Change the LED Indicators of IOC.
  • Add a new LED Indicator for Home Lock Flight when the distance between the aircraft and Home point is less than 8m.
Notices:
  • For safety reason, do not use power battery during firmware upgrade.
  • Make sure to reconfigure all parameters after upgrading firmware.
MessagePosté le: Ven 19 Juil - 20:57 (2013)    Sujet du message: Publicité
MessagePosté le: Lun 22 Juil - 09:19 (2013)    Sujet du message: WKM FW 5.24 Répondre en citant
Belle image de la démocratie chinoise Bannir
MessagePosté le: Mar 23 Juil - 22:45 (2013)    Sujet du message: WKM FW 5.24 Répondre en citant
C'est dans l'air du temps : Mac
Florent ne fait que relater le dernier firmware
Tiens pour infos .
Une entreprise qui vend des multis"drones" patin couffin après achat est capable de te donner accord de vol suivant ton plan de vol demandé !
Cela signifie que si ta carte na pas reçue la programmation et accord du périmètre de vol de cette même boite : Et bien ton multi ne décolle tout simplement pas.
Et bien à ton avis de quel pays peut bien sortir ce genre de chose ?
Réponse ? C'est très facile .............cherches pas loin....................
Lagaffe
MessagePosté le: Mer 24 Juil - 19:07 (2013)    Sujet du message: WKM FW 5.24 Répondre en citant
C'est normal, on ne doit pas voler au dessus des foules !
Chez nous on a une loi qu'on ne respecte pas, alors que chez eux ils font respecter une loi qui n'existe pas.
Je vous laisse philosopher sur le sujet...
MessagePosté le: Aujourd’hui à 05:21 (2018)    Sujet du message: WKM FW 5.24
