Carte ALEXMOS 3 AXES commande groupée!
MessagePosté le: Sam 14 Déc - 16:41 (2013)    Sujet du message: Carte ALEXMOS 3 AXES commande groupée! Répondre en citant
Je suis en relation avec un fournisseur chinois qui vends des alexmos offcielles 3 Axes ! Il est pret à me faire la carte 3 axes à 90$ = 65,5€ ! hors frais de port mais il faut compter 30€ de port pour le paquet en DHL. Soit environ 65+3€ la carte 3 axes!
C'est le prix pour 10 cartes. Pour 20 cartes c'est 85$ l'unité!
Je suis pret à en prendre 2 il me reste à trouver les 8 autres ;-)
Qui est interessé??
Voici le descriptif
SimpleBGC2.0-3 axis
3 Axis Controller Board Of Gimbal with Official AlexMos Firmware
In upcoming version 2.3 of firmware and GUI
"Supports battery monitoring and buzzer"
For the updated firmware to download link as below:
http://www.simplebgc.com/eng/downloads/
Here is changelog compared to 2.2 version:
v.2.3b2
- Bug fixed: multiple YAW turns caused variable overflow and instability
- Bug fixed: if the system starts in the YAW lock mode, the camera can accidentally rotate to fixed angle.
- If Flight Controller (EXT_FC) is connected and calibrated, the system becomes more stable in the bigger range of inclination angles (even pitched +-80 degrees)
- Battery monitoring and buzzer:
- Voltage drop compensation (PID becomes stable during whole battery lifecycle)
- Low-Voltage alarms and motor cut-off
(This feature will be supported on some newest boards or old ones with the hardware mod: voltage divider 33k/10k connected to pin 19 and active buzzer connected to pin 32. See user manual for details (coming soon)
- RC mapping improved: Any of PWM, Sum-PPM, or Analog modes may be set for any of RC inputs separately.
- it lets to use YAW-encoder or joystick together with RC control or External Flight Controller
- it may be required to re-configure RC inputs after firmware upgrade.
- Serial API extended by the 'C' command (camera control). Example written in C++ for Arduino is provided in doc.
- (GUI) New Full-screen mode available to better fit GUI in small displays
- (GUI) Bug fixed: firmware upgrade fails if working path contains spaces.
MessagePosté le: Sam 14 Déc - 16:41 (2013)    Sujet du message: Publicité
theguilt
MessagePosté le: Sam 14 Déc - 17:13 (2013)    Sujet du message: Carte ALEXMOS 3 AXES commande groupée! Répondre en citant
Que vaut cette carte? C'est pour des gros moteurs?
Plexus
MessagePosté le: Sam 14 Déc - 18:01 (2013)    Sujet du message: Carte ALEXMOS 3 AXES commande groupée! Répondre en citant
http://www.basecamelectronics.com/wheretobuy/
En lisant la premiere ligne, j'ai des doutes, c'est encore des copies.
MessagePosté le: Sam 14 Déc - 18:15 (2013)    Sujet du message: Carte ALEXMOS 3 AXES commande groupée! Répondre en citant
exact tout comme celles de LXRCModel qui fonctionne nickel d'apres Florent31 !
La carte normale c'est 110€+45€ soit pres du double ne l'oublie pas j'en ai une a la maison!
MessagePosté le: Sam 14 Déc - 18:38 (2013)    Sujet du message: Carte ALEXMOS 3 AXES commande groupée! Répondre en citant
Elles ont déjà des différences avec les flyduino qui saute aux yeux, entre autre la taille des CI et les perçages dans ces derniers...
Soyez prudents, c'est une source à cheveux gris si c'est pas 100% identique.
MessagePosté le: Sam 14 Déc - 18:58 (2013)    Sujet du message: Carte ALEXMOS 3 AXES commande groupée! Répondre en citant
je suis d'accord avec toi mais vu le prix ca peut valloir le coup de tester...
MessagePosté le: Sam 14 Déc - 19:15 (2013)    Sujet du message: Carte ALEXMOS 3 AXES commande groupée! Répondre en citant
Klr, ça peut valoir Smile
Je suis fatigué de ces test, je vieillis je crois, et c'est pas beau je l'admets Smile
Bon en plus de ça, j'achetes chez Flyduino les cables long pour aller jusqu'au MPU.
Mais allez y les djeuns, testez Very Happy
MessagePosté le: Dim 15 Déc - 02:33 (2013)    Sujet du message: Carte ALEXMOS 3 AXES commande groupée! Répondre en citant
j'ai une copie en 2 axe et upgradable la 107 de lxrcmodel, je n'ai pas encore eu le temps de la regler , je ferait un feedback .
thomasamoth
MessagePosté le: Dim 29 Déc - 17:10 (2013)    Sujet du message: Carte ALEXMOS 3 AXES commande groupée! Répondre en citant
Des news ? Wink
MessagePosté le: Dim 29 Déc - 17:45 (2013)    Sujet du message: Carte ALEXMOS 3 AXES commande groupée! Répondre en citant
Heu, ce n'est pas moi mais l'admin (Fabrice ) Qui a testé il me semble.
theguilt
MessagePosté le: Dim 29 Déc - 21:39 (2013)    Sujet du message: Carte ALEXMOS 3 AXES commande groupée! Répondre en citant
Ta regarder sur http://www.maximus-racing.com/fr/?
MessagePosté le: Aujourd’hui à 04:28 (2018)    Sujet du message: Carte ALEXMOS 3 AXES commande groupée!
