Flasher (bootloader+firmware) du compass chinois
MessagePosté le: Dim 9 Oct - 18:52 (2011)    Sujet du message: Flasher (bootloader+firmware) du compass chinois Répondre en citant
Pour ceux qui n'arrive pas a mettre a jour le firmware du compass par l'interface mktool (erreurs etc...)
Voici l'astuce :
1 : Télécharger Winavr (google)
2 : Aller dans le repertoire BIN de winavr et editer le fichier avrdude.conf (avec notepad par exemple), et, à la fin rajouter :
# ATmega168P
part
    id              = "m168p";
    desc            = "ATMEGA168P";
     has_debugwire = yes;
     flash_instr   = 0xB6, 0x01, 0x11;
     eeprom_instr  = 0xBD, 0xF2, 0xBD, 0xE1, 0xBB, 0xCF, 0xB4, 0x00,
            0xBE, 0x01, 0xB6, 0x01, 0xBC, 0x00, 0xBB, 0xBF,
            0x99, 0xF9, 0xBB, 0xAF;
    stk500_devcode  = 0x86;
    # avr910_devcode = 0x;
    signature       = 0x1e 0x94 0x0B;
    pagel           = 0xd7;
    bs2             = 0xc2;
    chip_erase_delay = 9000;
    pgm_enable       = "1 0 1 0  1 1 0 0    0 1 0 1  0 0 1 1",
                       "x x x x  x x x x    x x x x  x x x x";
    chip_erase       = "1 0 1 0  1 1 0 0    1 0 0 0  0 0 0 0",
    timeout         = 200;
    stabdelay       = 100;
    cmdexedelay     = 25;
    synchloops      = 32;
    bytedelay       = 0;
    pollindex       = 3;
    pollvalue       = 0x53;
    predelay        = 1;
    postdelay       = 1;
    pollmethod      = 1;
    pp_controlstack     =
0x0E, 0x1E, 0x0F, 0x1F, 0x2E, 0x3E, 0x2F, 0x3F,
0x4E, 0x5E, 0x4F, 0x5F, 0x6E, 0x7E, 0x6F, 0x7F,
0x66, 0x76, 0x67, 0x77, 0x6A, 0x7A, 0x6B, 0x7B,
0xBE, 0xFD, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00;
    hventerstabdelay    = 100;
    progmodedelay       = 0;
    latchcycles         = 5;
    togglevtg           = 1;
    poweroffdelay       = 15;
    resetdelayms        = 1;
    resetdelayus        = 0;
    hvleavestabdelay    = 15;
    resetdelay          = 15;
    chiperasepulsewidth = 0;
    chiperasepolltimeout = 10;
    programfusepulsewidth = 0;
    programfusepolltimeout = 5;
    programlockpulsewidth = 0;
    programlockpolltimeout = 5;
    memory "eeprom"
        paged           = no;
        page_size       = 4;
        size            = 512;
        min_write_delay = 3600;
        max_write_delay = 3600;
        readback_p1     = 0xff;
        readback_p2     = 0xff;
        read            = " 1 0 1 0 0 0 0 0",
                          " 0 0 0 x x x x a8",
                          " a7 a6 a5 a4 a3 a2 a1 a0",
                          " o o o o o o o o";
        write           = " 1 1 0 0 0 0 0 0",
                          " i i i i i i i i";
loadpage_lo = "  1   1   0   0      0   0   0   1",
 "  0   0   0   0      0   0   0   0",
 "  0   0   0   0      0   0  a1  a0",
 "  i   i   i   i      i   i   i   i";
writepage = "  1   1   0   0      0   0   1   0",
 "  0   0   x   x      x   x   x  a8",
 " a7  a6  a5  a4     a3  a2   0   0",
 "  x   x   x   x      x   x   x   x";
mode = 0x41;
delay = 5;
blocksize = 4;
readsize = 256;
    memory "flash"
        paged           = yes;
        size            = 16384;
        page_size       = 128;
        num_pages       = 128;
        min_write_delay = 4500;
        max_write_delay = 4500;
        readback_p1     = 0xff;
        readback_p2     = 0xff;
        read_lo         = " 0 0 1 0 0 0 0 0",
                          " 0 0 0 a12 a11 a10 a9 a8",
                          " o o o o o o o o";
        read_hi          = " 0 0 1 0 1 0 0 0",
                           " o o o o o o o o";
        loadpage_lo     = " 0 1 0 0 0 0 0 0",
                          " 0 0 0 x x x x x",
                          " x x a5 a4 a3 a2 a1 a0",
                          " i i i i i i i i";
        loadpage_hi     = " 0 1 0 0 1 0 0 0",
                          " 0 0 0 x x x x x",
                          " i i i i i i i i";
        writepage       = " 0 1 0 0 1 1 0 0",
                          " a7 a6 a5 x x x x x",
                          " x x x x x x x x";
        mode        = 0x41;
        delay       = 6;
        blocksize   = 128;
        readsize    = 256;
    memory "lfuse"
        size            = 1;
        read            = "0 1 0 1 0 0 0 0 0 0 0 0 0 0 0 0",
                          "x x x x x x x x o o o o o o o o";
        write           = "1 0 1 0 1 1 0 0 1 0 1 0 0 0 0 0",
                          "x x x x x x x x i i i i i i i i";
    memory "hfuse"
        size            = 1;
        read            = "0 1 0 1 1 0 0 0 0 0 0 0 1 0 0 0",
        write           = "1 0 1 0 1 1 0 0 1 0 1 0 1 0 0 0",
    memory "efuse"
        size            = 1;
        read            = "0 1 0 1 0 0 0 0 0 0 0 0 1 0 0 0",
                          "x x x x x x x x x x x x x x x o";
        write           = "1 0 1 0 1 1 0 0 1 0 1 0 0 1 0 0",
                          "x x x x x x x x x x x x x x x i";
    memory "lock"
        size            = 1;
        read            = "0 1 0 1 1 0 0 0 0 0 0 0 0 0 0 0",
                          "x x x x x x x x x x o o o o o o";
        write           = "1 0 1 0 1 1 0 0 1 1 1 x x x x x",
                          "x x x x x x x x 1 1 i i i i i i";
    memory "calibration"
        size            = 1;
        read            = "0 0 1 1 1 0 0 0 0 0 0 x x x x x",
                          "0 0 0 0 0 0 0 0 o o o o o o o o";
    memory "signature"
        size            = 3;
        read            = "0 0 1 1 0 0 0 0 0 0 0 x x x x x",
                          "x x x x x x a1 a0 o o o o o o o o";
Ensuite :
3 : Télécharger le bootloader et le firmware du compass :
http://svn.mikrokopter.de/listing.php?repname=MK3Mag&path=/tags/V0.23a/…
4 : Renommer les 2 fichiers avec des syntaxes simples, par exemple bootloader.hex et firmware.hex et copier c'est 2 fichiers dans le repertoire de winAVR
5 : Lancer une fenetre dos et aller dans le repertoire winavr
taper :
Code:
avrdude -c USBasp -p m168p -P usb -U flash:w:bootloader.hex -u -U lfuse:w:0xe2:m -U hfuse:w:0xdd:m -U efuse:w:0x00:m
Si tout est ok, passer au flash du FW :
Code:
avrdude -c usbasp -p m168p -P usb -U flash:w:firmware.hex
Et voila votre compass chinois revie !
Si jamais le tuto vous a aidé, n'hesitez pas a mettre un petit mot, ca fait toujours plaisir !
MessagePosté le: Dim 9 Oct - 18:52 (2011)    Sujet du message: Publicité
MessagePosté le: Dim 9 Oct - 21:54 (2011)    Sujet du message: Flasher (bootloader+firmware) du compass chinois Répondre en citant
un grand merci à toi !
mon mk3mag revit !
je l'ai calibré tout à l'heure sans problème.
MessagePosté le: Lun 10 Oct - 14:31 (2011)    Sujet du message: Flasher (bootloader+firmware) du compass chinois Répondre en citant
Un grand merci Toine, je pense qu'un admin devrait l'épingler.
MessagePosté le: Mar 25 Oct - 22:46 (2011)    Sujet du message: Flasher (bootloader+firmware) du compass chinois Répondre en citant
Salut, j'ai le problème en question avec le mk3mag.
Pour faire cette manipulation, a t'on besoin d'un avrdude ou le mkusb peut il faire l'affaire?
MessagePosté le: Mer 26 Oct - 13:25 (2011)    Sujet du message: Flasher (bootloader+firmware) du compass chinois Répondre en citant
de mon coté, le mk usb a suffi : choisir l'autre connecteur 10 pins de celui  qu'on connecte à la FC.  Ne pas oublier le jumper pour alimenter en 5V...
si ça va pas: programmateur et avr
ZarbeL
MessagePosté le: Mer 2 Mai - 08:28 (2012)    Sujet du message: Flasher (bootloader+firmware) du compass chinois Répondre en citant
moi j'arrive a mettre a jour mais il me dit  que la fc n'est pas compatible  (navi 0.26f & 0.86d)
Bumblebee tuning fpv
Mk FC2.0 p&p octo
MK 1.3 + navi quad x
KK quad Gaui x330
ZarbeL
MessagePosté le: Lun 7 Mai - 12:19 (2012)    Sujet du message: Flasher (bootloader+firmware) du compass chinois Répondre en citant
meme avec la derniere mise a jour, impossible que la navi et la FC communique...
j'arrive a avoir la FC depuis la connection navi... la navi et le compass au vert... et depuis la FC, fc et bl au vert... mais a aucun moment la navi comprend la FC...
j'en peu plus!
Mk FC2.0 p&p octo
KK quad Gaui x330
MessagePosté le: Aujourd’hui à 13:07 (2017)    Sujet du message: Flasher (bootloader+firmware) du compass chinois
