Aller à la page: 1, 2, 337, 38, 39  >
MessagePosté le: Jeu 22 Déc - 08:41 (2011)    Sujet du message: Futur électroniue de vol : le YS-X6 Répondre en citant
Et un chinois de plus. Il ressemble beaucoup au Wookong. APparemment proposé à 6500 yuan. De ce que j'ai vu Maximus est sur le coup....
Quelques caractéristiques :
YS09UAV flight control system is a high performance, low cost and miniaturization of UAV flight control system, can be loaded in different flight platform, can be widely used in scientific research, tactical reconnaissance, emergency rescue, maritime reconnaissance, aerial forest fire prevention, image, artificial rainfall, agricultural survey, pipeline inspection and other fields.
1、System characteristics
Integrated 4Hz update rate of GPS, GLONASS, extensible Beidou navigation;
Integrated digital space velocity, pressure sensor, 0.1mba of high accuracy, high measuring scalable radio altimeter;
Integrated low cost low weight by IMU, with GPS modified Kalman filter calculation the most close to the real situation of the aircraft attitude, the dynamic accuracy of 2 degrees, to eliminate the instantaneous acceleration, gyro drift on the attitude calculation of effects;
Positioning system can be extended with differential GPS, to realize the precise route control and automatic downhill;
External high precision inertial navigation components, various types of AHRS, vertical gyro, and external turbojet engine electronic control unit ( ECU );
Control of airborne servo rotating, CCD zoom, algorithm can control the tilt locking ground fixed targets;
Equidistant, fixed-point exposure camera control, and the machine preservation to take pictures of aircraft telemetry parameters;
Real time modification, upload routes, real-time adjustment of flight control parameters;
Flight control hand operation has digital recording, playback control process analysis;
Real time display of 3 axis acceleration value, 3 axis gyro value IMU sensor information;
7 - 20V wide voltage input, 12 bit A / D acquisition voltage monitoring;
Multiple PID combined control algorithm, 256 ~ 1024 tasks waypoint;
" A fool" operation, a variety of flight control mode: full autonomy launching, autonomous hand throwing off, autonomous cruise flight, autonomous" one-click" recovery, which fly which, in situ;
The user can set the safety protection function; voltage monitoring, engine speed, engine and car accident monitoring, safety protection;
Support Lab flight simulation function, remain within doors to prejudge the flight effect;
9 channel servo output, time, distance control task of taking pictures rudder motor for opening the umbrella, umbrella, support the cut, open spaces, such as throwing the actuator;
Supports full aileron roll turning turning, pressure gradient, support the routine, V, H tail tail, delta wing and various layout;
In the mooring platform with high altitude suspension 7 days after acceptance program assessment, military equipment, strict examination, high and low temperature, vibration, shock, electromagnetic compatibility and other indicators in line with national military standard.
Des vidéo pourries (j'ai hésité à les mettre, yen a marre de se faire prendre pour des cons avec ces vidéos de démonstration ou tout marche) :
Il va falloir que holger se bouge!!!!
MessagePosté le: Jeu 22 Déc - 08:41 (2011)    Sujet du message: Publicité
MessagePosté le: Jeu 22 Déc - 09:31 (2011)    Sujet du message: Futur électroniue de vol : le YS-X6 Répondre en citant
hihihi,
elles sont ou les perfs de ce  controleur ?
un quad qui vole ? ...j'en ai une pelletée à la maison.... Very Happy
Les chinois devraient apprendre à faire des vidéos un peu didactiques, comme celles de Holger ( ou meme celles de DJI... ), où le matos est mis en situation  et les perfs appréciées...
Yves2000_ch
MessagePosté le: Mer 4 Avr - 19:59 (2012)    Sujet du message: Futur électroniue de vol : le YS-X6 Répondre en citant
Il me semble le prix. À voir. Embarassed
MessagePosté le: Mer 4 Avr - 21:17 (2012)    Sujet du message: Futur électroniue de vol : le YS-X6 Répondre en citant
en fait c'est a verifier mais voici l'histoire en gros:
les inventeurs du wookong se sont tiré de chez dji
il possede le code source du wookong m, dji est d'ailleurs bien emerdé car ils ne peuvent (pour l'instant) faire evoluer de wookong m
les inventeur on donc remonté une boite ou il proposerons  ce controleur de vol qui est un clone du wkm mais avec plus de fonction car eux ils peuvent le faire évoluer!!
vrai ou faux toujours est il que dji peine a faire des modifications profonde sur le wkm
MessagePosté le: Mer 4 Avr - 22:12 (2012)    Sujet du message: Futur électroniue de vol : le YS-X6 Répondre en citant
Ils en auraient vendu en Chine. Je viens de leur envoyer un mail. Je vous donne leurs tarifs dès qu'ils me répondent.
MessagePosté le: Jeu 5 Avr - 02:55 (2012)    Sujet du message: Futur électroniue de vol : le YS-X6 Répondre en citant
ils ont moins de force de frappe commerciale que dji mais ils irons plus loin pour le dev!
catlord
MessagePosté le: Jeu 5 Avr - 09:07 (2012)    Sujet du message: Futur électroniue de vol : le YS-X6 Répondre en citant
Shocked !
et bah bonjour le bordel Sad
DJI diot être sacrément emmerdé avec cette histoire et c'est très dommage pour le suivit produit :/
Peut on te demander d'où tu tiens cette info ?
MessagePosté le: Jeu 5 Avr - 09:59 (2012)    Sujet du message: Futur électroniue de vol : le YS-X6 Répondre en citant
avis perso:
ce genre d histoire me reconforte dans mon idéé de prendre que des cartes a moins de 100euro qui elles evolueront continuellement comme les projets open source...car meme si un wookong est bien plus performant qu un mulitwii,ça le reste mais pour combiens de temps encore????si le wk n evolue pas plus que ça,sans devoir repayer un module,beaucoups risquent de se pencher sur une autre plateforme
MessagePosté le: Ven 6 Avr - 18:26 (2012)    Sujet du message: Futur électroniue de vol : le YS-X6 Répondre en citant
J'oubliais de donner l'adresse de leur site :
http://www.zerouav.com/
MessagePosté le: Ven 6 Avr - 20:10 (2012)    Sujet du message: Futur électroniue de vol : le YS-X6 Répondre en citant
Et moi le post sur rcgroup : http://www.rcgroups.com/forums/showthread.php?t=1560300
Les chinois qui se volent entre eux Mort de Rire Mort de Rire
MessagePosté le: Ven 6 Avr - 20:24 (2012)    Sujet du message: Futur électroniue de vol : le YS-X6 Répondre en citant
yaura toujous un garzier qui va reussir a faire ce que l autre a fait dans tous les cas personne n est irremplacable
maximus
MessagePosté le: Ven 6 Avr - 21:31 (2012)    Sujet du message: ZEROUAV Répondre en citant
Hello,
Je fais un petit tour en passant et on parle de moi...pas en mal...pour le moment Mr. Green
Je ne rentrerai pas dans la polémique de qui était chez qui et a fait quoi....
Je suis en contact avec ZEROUAV depuis environ un an (début Mars 2011) et il est vrai que les tout premiers vols n'étaient pas folichons...
Les résultats s'étaient nettement améliorés en début d'été mais DJI a commercialisé sa carte et a raflé la première mise !
Pour faire bref, je suis resté au contact et leur carte sort fin du mois, début Mai.
Mon système est parti aujourd'hui d'usine Okay
Pour les prix, j'ai bataillé ferme pour que ceux-ci soient "raisonnables"...
Ils doivent être encore affinés mais pour le kit standard, il sera très proche de celui du WKM mais avec les toutes les fonctions suivantes (copié/collé de mon post sur RCG).
- MC+IMU+GPS+LED+WIFI (of course, the hardware !)
- GS Software(Support Android and Apple System)
- Auto Takeoff/Go Home /Landing
- realtime Flight Status
- Gimbal Stabilization Lock (POI)
Within 10s, Fly circle route with Fixed Radius 20m (that means "Within 10second, it can fly a round whose radius is fixed by 20meters, but after 10 seconds, it can fly another circle whose radius is also 20meters")
- Low Voltage Protection Warning
- Click&Go: Click&Go Fly within 30m, can't repeat operate within 20s
- 4 Waypoints design within 100m
En PLUS: programmation et PILOTAGE de la machine par WIFI avec un Iphone/Ipad ou téléphone/tablette Android...
voilà une vidéo de l'usine pour le décollage auto/RTH/attérissage auto et pilotage avec un téléphone Samsung
Et une petite démo de vol avec pilotage et navigation avec une tablette...
Je vous en dirai plus à mesure des infos que j'obtiens.
Bon weekend de Pâque à tous
Maximus
www.maxicopter.com
ZarbeL
MessagePosté le: Dim 8 Avr - 05:45 (2012)    Sujet du message: Futur électroniue de vol : le YS-X6 Répondre en citant
alors là c'est genial!
Bumblebee tuning fpv
Mk FC2.0 p&p octo
MK 1.3 + navi quad x
KK quad Gaui x330
MessagePosté le: Dim 8 Avr - 08:46 (2012)    Sujet du message: Futur électroniue de vol : le YS-X6 Répondre en citant
Le principe est sympa (et dans l'aire du temps) mais perso je trouve la commande via tablette ou autre un peu gadget Rolling Eyes
maximus
MessagePosté le: Dim 8 Avr - 09:29 (2012)    Sujet du message: Futur électroniue de vol : le YS-X6 Répondre en citant
c'est pas tant le pilotage que la programmation elle même !
Pas besoin de mener ton PC au terrain, tu fais tout avec ton téléphone Wink
www.maxicopter.com
MessagePosté le: Aujourd’hui à 12:39 (2017)    Sujet du message: Futur électroniue de vol : le YS-X6
Page 1 sur 39
